Control reference is invalidated (Error 1055) only when running in built executable (LabVIEW 2012 Runtime Engine)
I have an application that works normally when run in the LabVIEW 2012 development environment, but when run from a built executable, a reference to a tree control becomes invalidated after what seems to be a set amount of time, giving error 1055. I've disabled the subVI where this occurs then re-built, then it just occurs in another VI that uses the reference upstream. Tried Re-linking subVIs, uninstalled LabVIEW DSC module as someone suggested to another similar post, re-made the build spec from scratch, tried wiring up the tree control reference directly to the subVI's connector pane to be sure it's getting a valid reference, and still I get error 1055 when attempting to run.
I found a similar but slightly different post with no solution that might be useful for anyone attempting to look into this:
https://forums.ni.com/t5/LabVIEW/Control-reference-goes-invalid-in-built-applications-if-passed/td-p...
Any help would be appreciated
Ryan
Certified LabVIEW Architect
(3,230 Views)
My only guess is that one of the advanced build options doesn't like being set at its default value.
Bill
CLD
(Mid-Level minion.)
(3,210 Views)
Bill,
I should have added that I've tried building with combinations of enabled and disabled debugging, LabVIEW 8.x file layout, and SSE2 optimization to no avail.
Ryan
(3,205 Views)
@Ryan_Chamberland wrote:
Bill,
I kind of figured you would have covered those bases, but I had to make sure.  How about the disconnecting typedef's and stuff like that?
Bill
CLD
(Mid-Level minion.)
(3,192 Views)
Accepted by topic author Ryan_Chamberland
Welp, turns out it was because there was a file not in the proper location relative to the built application, and due to improper error handling, this manifested itself as an invalid object error. Let this be a lesson to anyone who sees something similar and is banging their head over it
Ryan
(3,190 Views)
Ouch.  I was too afraid to suggest this.
Bill
CLD
(Mid-Level minion.)
(3,169 Views)
