Control inputs into a text file
Hello all,
does anyone know how to save into a text file different numbers the user puts using controls??
I have been tried using arrays but I didn´t success 😞
Thanks!!
(4,534 Views)
Can you show us how you did (Attach a VI in 2013 or earlier version)
(4,529 Views)
Hi lacorgui,
you could format your numbers into a text file like this:
This is just one method of saving numbers to files. There are a lot more, just look at the file functions palette!
(4,520 Views)
I got it when my inputs are fixed, converting numbers to strings and then concatenating those. However, this does not work when I have different values during time, for example during a measurement.
What I want is to save different values (namely A, B and C) at different times in a same text file. For example, for a time X I want A, B and C values in three different columns, for time X+1 again the values in a different row and so on.
I´ll try to post the vi soon!
(4,513 Views)
Thank you GerdW,
I´ll try doing this, at least for fixed numbers (it seems more tidy than my method ;))
(4,510 Views)
Use WriteToSpreadsheetFile…
(4,509 Views)
If you are trying to save and load control values, OpenG has a Save Panel to INI and Load Panel From INI that is quite handy.  Just pass the VI reference to the function, and a path for the file to be saved to and the front panel will be saved to a human readable file.
(4,468 Views)
