02-08-2007 10:13 AM
02-14-2007 01:53 AM
Hi maumontesi,
Your, is a very challenging problem; effectively I did some researches and as you said I found no specific drivers for your HP4195a certified by National Instruments.
However, I suggest you to open LabVIEW and from the menu bar click on Help>>Find Instrument Drivers and here deselect the option NI certified drivers only; Doing so you will find some drivers for HP4195a, check if they're right for what you need to do. If not, you should try to search some drivers that are not specific for your HP4195a but are similar ti them.
Searching, I also found two forums in which there are people that have problems with HP4195a. I give you the links:
http://forums.ni.com/ni/board/message?board.id=170&message.id=118282&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=140&message.id=11171&requireLogin=False
I hope I've been of some help.
carlo>
