Control global variable used in sub vi
I've created a vi to read an instrument and to initiate its calibration with labview. This VI stores data in a global variable containing measurments and status of the instrument.
Now what I'm trying to do is create a sub vi with this to read&write 2 exactly identical instruments so I can finally create a VI that read all 3 instruments simultaneously.
How could I create a control on the global variable used by the sub VIs since it is the only thing that will change along with its COM port ?
I included a screetshot of the current VI.
(2,835 Views)
I would make an array of values and then you just pass in which value to update.  I would actually take it a step further and make an Action Engine that can update the data and return the data.
(2,818 Views)
