Control design and simulation palette
i am also facing this problemm can you tell me how can i get it or from where i can download and install it?
@Barp wrote:
Maverick
Yes... the Control Design and Simulation Pallete is a reserved to the following toolkits (System Identification, Control Design, Simulation Module, PID, Fuzzy, SIT and State Diagram).
If you have the Developer Suite, you have access to PID and Fuzzy. If you have the Dev Suite with Control and Simulation option, you have access to the other toolkits.
Hope this helps!
@Barp wrote:
Maverick
Hope this helps!
Message 31 of 32
(446 Views)
Just google "LabVIEW Control Design and Simulation Module":
http://www.ni.com/download/labview-control-design-and-simulation-module-2017/6715/en/
And if you have the right license, this should be able to be used.
If you are an academic license, then you probably should work with your admin to get the right installer and license. Please contact support or sales for further help in this area.
Barp - Control, Simulation, RTT and HIL - National Instruments
Message 32 of 32
(443 Views)
