Control design and Simulation loop Linear transfer function block is uneditable
In the "Transfer function configuration.png", the numerator and denominator are stuck in their respective default values and cannot be modified. Preview of the transfer function is not seen.
For example programs, when the transfer function configuration window is opened, the exact same Transfer function configuration as in the attached picture is seen. But the example programs work as intended.
Also attached is NI package manager picture, for repair and remove the control design and simulation module was selected and the associated, some other products to be removed/repaired were also automatically repaired and removed.
Please refer to the version of the cdsim module in the package manager picture.
(1,489 Views)
Dear Gowthaman_Capsys,
Have you tried repairing the cdsim from package manager?
best,
anasei.
(1,401 Views)
