Control about LabView activex a CANoe test environement
I have a problem, I want control about LabView a CANoe test envirionment.
But If I add an automation refnum, I can only choose between 2 classes CANoe.IApplication3 and CANoe.IMeasurement, I saw a example which are used a autmation reference CANoe.ITestCase and about invoke node a ITestSequence and a proberty node ITestCase which selected the test case.
Could help me somewhere how I can show a access to the other classes?
The example which I find is stored in LabView 2014 and I used 2013 so I can't open this, have somewhere maybe a Vi example which open a CANoe Cfg and start a test case?
Thank you
(2,845 Views)
I find the missing classes, if I create refnum I can do this about the context menu "Select Active X Class" and "Browse Button", I can select the "CANoe 8.5 Liberay Version 1.2e" and than I can choose the needed class.
But I don't know, which step I must do to start a single test case of my CANoe environment.
In the moment I can only open a CANoe.Cfg but the other steps are not working, I tried it in the moment in the following way.
(2,810 Views)
