07-05-2012 07:46 PM - edited 07-05-2012 07:47 PM
In a waveform graph is their a way to set the lower graph Y limit at zero and then have it autoscale the maximum Y limit as a percentage (150% for example) of the maximum Y graph value ?
Direction to examples or a starting point to read up on would be great !
Joe
Ireland
Solved! Go to Solution.
07-05-2012 08:01 PM
Turn off autoscale and set the max with a property node based on the array max of the data.
07-10-2012 07:19 PM
Thank you ! The property Node offers some functionality !
Working on implementing a front panel interactive sliding fft window over measured sound data, We'll be speaking again soon I feel
