Control Table - Runtime
I am displaying some parameters and the corresponding values in the table. I want to give the option to the user(runtime) to  select the single parameter(i.e. single row) and move it "up" or "down" in the display.
Kindly suggest me, how to implement or which property can be used. I am using Labview 8.5.
Regards
Meena
(2,780 Views)
Since a table is 2D array of STR you need just a "Delete from Array" to get the line to move and an "Insert into Array" with the index decremented or incremented depending from the direction.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,767 Views)
