Control Slide in subvi by reference
Im stumped. I would like to display a progress bar in my main vi as a subvi analyzes a file. Simple right? I passed a reference of the slider indicator to the subvi. I created a Property Node, selected the 'value' property for the slider and set to write. Basically the subvi is analyzing data and changing the slider value based on file position. The VI crashes on the value property.
What am I doing wrong? Isn't that how you access a control on another VI?
[will work for kudos]
Message 1 of 8
(5,557 Views)
This doesnt work. Why?
Message 2 of 8
(5,549 Views)
Your front panel is not updated until the subVI is completed. You need a way to pass information from the subVI to main VI. In the attached example I used a notifier to pass the slide value and a while loop (that wait for notification) in the main to update the slide control.
Ben64
Message 3 of 8
(5,542 Views)
Forget the previous post, I took a closer look and there is a simple reason why the slide don't update. The slide control is a  takes U8 values. The default maximum is 255. You are sending i/100 values to this control so the 2 possible values it can take is 0 and 1. Set N=255 and connect i to the property node value input and you will see the front panel slide update from 0 to the max 255 U8 value.
Ben64
Message 4 of 8
(5,525 Views)
After verification the default slide max is 100. Go to slide properties -> scale to change the max value.
Ben64
Message 5 of 8
(5,519 Views)
You can also change the slider representation to DBL and set the Range for Min=0 and Max=1 since the value you are writing will be a fraction between 0 and 1.
- tbob
Inventor of the WORM Global
Message 6 of 8
(5,506 Views)
For use cases like this I love to use an Action Engine to maintain the referance to the control.  Then I can call it from anywhere at any level in my code to update the GUI.
Here's a snippet of "UI Progress.vi" demonstating the concept.
"Should be" isn't "Is" -Jay
Message 7 of 8
(5,484 Views)
Thanks for the help guys. You're right I meant to divide by 10. Already set the slider to range 0 to 100
Message 8 of 8
(5,439 Views)
