Control Siglent SDG2000X series function generator via Labview
Hi guys,
I am new to LabVIEW, and am trying to control the Siglent Function generator (SDG 2042X) using my laptop. The task is to simply generate a pulse sequence.
However, I am having issue when I run the program. The error message is indicated as follow
The code is pretty much same as what given in the example, which I get the same error message there.
The code looks like this:
Any advice would be really appreciated.
(1,960 Views)
Hi Hyunwooss,
Do you see this "-108" text in the error message? This is an error generated by your Siglent device because you sent a malformed command string!
Read the (programming) manual of your device, it should explain this error code. Then debug your VI to find the command, which enforces that error message!
(1,916 Views)
