Control/Indicator inside Error Case?
Hi all,
I forgot somthing that is starting to bother me.  If I create a subvi with a error case structure.  Should I put all my indicator/controls inside or outside the structure, and why?   Thanks!
(3,248 Views)
Accepted by topic author jyang72211
Until I read otherwise, I assume the advice from the "Clear As Mud" Post is still valid.  Try to put all controls/indicators on the root diagram.
(3,235 Views)
I will remember to put them outside of the error case.  Thanks!
(3,169 Views)
