hi,
I'm trying to send an hex word (Ox5B)word on the serial port in order to reproduce a periodic signal on Tx. I'm using the attached VI. The main question is concerning the writing in the "while" or "for" loop. In fact as you will see in TEK00013 (ch1=IR receiver signal, ch2=IR diode emitted signal - Tx), when I'm sending "5B" in my "while" loop I have intervals (big ones) between the writings , even when I remove every timing between loops. I also tried to change the word written in the serial port using the one that corresponds to the maximum length stimulation to the scope. This word is "5B5B 5B5B 5B5B 5B5B 5B5B 5B5B", a "5B" more reduce the length. When writing it consecutively I have the signal of TEK00012 and the main problem is the gaps I have between two emissions. You could also remark that the receiver sees these gaps, it losts the modulation.
I'd like to know how to send this word with no interval between consecutive writings to avoid this phenomenon. I'm not aware of every RS-232 principles so it's possible I don't know the most appropriate function to use.
I hope someone can help me.
Thank you in advance.
Bim
