Continuous plotting in real time
Hello All!
I'm using XY graph to plot multiple data receiving from serial com and I wanted to show the graph in real time. My question is, how to do it not relative to start time?
Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(6,682 Views)
Well, If I understand your question correctly then this should do it.
Tim
GHSP
(6,676 Views)
What I'm trying to do is to keep plotting the data and not shrink them. Once the X axis reached certain point (assuming 0-50) then the axis value will update like 1-51, 2-52, 3-53 and so on..
Thanks for the reply..
______________
KowdTek
LabVIEW 2009
(6,666 Views)
Accepted by topic author KowdTek
Why are you using an XY Graph instead of a chart?
(6,657 Views)
This isn't pretty but maybe you can take something from it to get you where you want to go.
Tim
GHSP
(6,653 Views)
The way you are numbering it makes it hard.
Tim
GHSP
(6,652 Views)
Thanks to both of you!!!
I've just replaced XY graph to WF chart and little modification & it did exactly what I wanted to do...Smiley Wink
______________
KowdTek
LabVIEW 2009
(6,632 Views)
