Continuous XY graph with real time and data
Hello all,
I wish to do the following:
I want to generate random numbers in one column on my array and have the second column with the current time and date. I want to then plot only the random numbers that have been generated along with the TIME from the Get Date/Time function. I want to put this into an array and plot them with a XY graph rather than in a spreadsheet.
I have done this top part.
However, I would like it to run continuously, instead of waiting to gather the data, and THEN plotting the numbers. Essentially, the random number generator i put is supposed to represent an 1d array that will be constantly updating itself from signal inputs continuously.
Side note: For my purpose i want to get the time indepent, rather than use a waveform chart and use the internal clock of that vi. I would liek to use an XY graph and not a waveform chart/graph.
Thank you.
Message 1 of 14
(18,114 Views)
Use the "build xy graph*" express VI and set it to not clear data between calls. Now simply give it one point with each call and it will act similar to a chart.
* place the "express xy graph" and you'll get that automatically on the diagram.
Message 2 of 14
(18,100 Views)
I can't use the time output to connect as the X input for the express XY graph vi. They are not of the same type
Message 3 of 14
(18,095 Views)
Attach your VI. Of course this can be made compatible!
(Of course you could just build your data up in a shift register. probably the preferred solution)
Message 4 of 14
(18,093 Views)
Thank you for your help !
Message 5 of 14
(18,086 Views)
Insert a "to DBL" into the timestamp wire.
The graph terminal needs to be inside the loop. Why do you have so many loops???
Message 6 of 14
(18,082 Views)
Message 7 of 14
(18,078 Views)
Why is the time stamp converting into a number like that?
Also, I would like the graph to update the data continuous by shifting the data over. Instead of squishing the data points together.
I feel liek i shuld resort to a waveform chart...
Message 8 of 14
(18,072 Views)
Can you describe that in more technical terms? You can change the autoscaling of the x axis in any way you want.
Maybe you want to use a fixed history size. This woiuld need to be done externally. You could also use the "collector express VI".
Are the data points spaced equally in time? I assumes they are not, else why would you use an xy graph in the first place?
Message 9 of 14
(18,061 Views)
Ideally, I would liek to display what the waveform chart is displaying in the XY graph. If you run the program continuously, i want to see the past data as well and let it update itself . "shifting the window" of the chart. The X-axis should be real time and the y values should be in array format.
Message 10 of 14
(18,050 Views)
