Continuous Sample TTL signal generation with DAQmx
OK I know this has been asked many times but it all sees like different versions. I currently have a continuous data collection going for about 10 analog input signals at 10kHz. All working great.  I would like to replace an existing function generator (physical unit) with a command from labview. Always producing a square wave (TTL) 0-5 volt with a constant frequency and duty cycle.   My DAQ is one of the USB styles not sure of the model BNC interface primarily cost quite a bit $3k.  I cannot find any sample code to do this.  I don't use DAQ Assistant in my original code.
I would like to think I would just add the digital output to my continuous while loop but am not sure how it is done.  I could upload my analog input code but it would be fairly meaningless as it is full of signal labeling etc.
So I guess the quick question is. How to generate a TTL signal in continuous sampling mode (10kHz) without using DAQ assistant.  I'm basically commanding a solenoid to open and close which my system is taking high speed data.
thanks
Jason
(942 Views)
If it's continuous you can just run a separate task and you won't need to "service" it. If your DAQ is a new-ish model (63xx or 64xx) your digital outputs will have a clock source they can use. If it's a 62xx or 61xx you would need to do some shenanigans with other clocks but those are pretty old.
Use Help - Find Examples and see if you can find a digital output example. That would get you up and running super quick.
(939 Views)
Or better yet, just use a counter task to generate a continuous pulse train.  No buffers or bus bandwidth needed.   There's a shipping example to show how.
- Kevin P
(901 Views)
- Kevin P
(893 Views)
Thanks Kevin P.
I'll look into this option. I've never really used NI HW for outputs, just inputs. I've seen a number of forum posts related to generating output signals but not typically along with DAQmx code as well. Merging those two together is where I often struggle. To me the DAQmx blocks are just nonsense. I want to record a signal or in this case output a pulse pattern. I don't care about start tasks, end tasks, etc. The "Voltage - Continuous Output.vi" is obnoxiously long to send out a sine wave output to an AO channel. It's fine for the power user but those of us that write new labview code once every 3 years not as fine.
Thanks again Kevin. I'll look to the counter code provided.
Jason
(865 Views)
