Continuity Test
How can we use NI USB-4065 to perform continuity test?
(1,625 Views)
If you mean the traditional continuity beeper that handheld DMMs come with, it doesn't quite exactly do that. But by using the NI-DMM soft front panel, you can achieve something similar.
https://forums.ni.com/t5/Digital-Multimeters-DMMs-and/Continuity-testing-and-NI-4072-DMM/td-p/306396...
Santhosh
Soliton Technologies
(1,615 Views)
It seems kinda straight forward if you think about it.
A continuity tester is just an ohm meter that beeps when the ohms measurement is less than a certain value like <1 ohm.
=== Engineer Ambiguously ===
(1,509 Views)
