Constructing the Tree with tag
I need to construct the tree control with data which has unique keys. Please refer below image. Each element I need to pass the unique keys.
From above diagram, assume that "Project" should have "1" as a tag. Similar way, "Structure" should have "2" as a tag, "Substruc" should have "3" as a tag, "Pile" should have "4". So, If I adding the new element under the tag "1"(which is "Project"), my new element should go under "Project". Similarly, I have to add new elements based on their tag names. Everything I need to in programmatically.
(2,800 Views)
Use an invoke node for the tree.  Select Edit Tree Items -> Add Item
(2,792 Views)
Accepted by topic author azadplc007
Got the output. Attached snippet here...
Never mind about the broken wire. That is coming from another loop. Since I made the snippet only for this section, it got to be broken...
(2,730 Views)
