I am having a problem with Labview 5.1.1 running on Windows 2000. When openning a vi that was previously saved on a Windows NT machine running Labview 5.1.1 all constants on the diagram are compacted. Some constants only show one character even with size to text enabled. If I disable sized to text and then enable it the constant will be diplayed correctly sized to text. Anyone know of a setting or patch for this?
Try changing your display settings on WIN2000 before you launch labview OR open the VI's. When in display properties goto the "appearance" tab. In the "Scheme" pulldown select "windows classic". Now apply these settings and close the dialog.
No launch labview and open the VI to see if it makes a difference.
