Connection to an openoffice database
does anybody know how to access the openoffice database functionalities using LabVIEW?
Are there any dlls or activeX, or anything that can be called from LabVIEW, which allow getting and setting values in a specified table?
Thanks in advance.
(3,320 Views)
Reportedly OpenOffice 1.1 comes with an ActiveX control.
That is what you will need to interface to LabVIEW.
(3,316 Views)
Thank you for the answer but I still have doubts!
I have installed the version 2.0.1 enabling the activeX features during the installation. What I need now is to know  how to configure the "automation open" function in LabVIEW, since I can't found any item referred to openoffice browsing the select activeX class.
(3,306 Views)
I did something like that for Microsoft Access.
I basically read the examples for ADO Active Data Objects using Visual Basic and "translated" that to LabVIEW. You might want to take a look at the example VIs to do this with Access and get an idea of how to do it.
(3,296 Views)
