Connection of Rexroth linear motor (and drive) to LabView for changing parameters (velocity, torque, ...) to test peformance of nano-generator.
I would like to know if it is possible to connect (directly or indirectly) a 3-phase synchronous pm-motor from Rexroth to LabView and then tune/configure/program and/or change its parameters using LabView. The goal is to connect the motor/drive to LabView, directly or indirectly, so that I can toogle with the motors' parameters (velocity, torque, frequency, etc), in order to see the consequences in the performance of a triboelectric nano-generator. The final goal is to use the system to test a wave energy harvesting system.
(545 Views)
Please share the link to your motor/controller. In general, if it has some communication port like USB, RS232 or sort to connect to a PLC or a computer, then probably yes, you could control it in LabVIEW. To answer which extent it is controllable depends on what features are exposed to be adjusted over the communication port.
Santhosh
Soliton Technologies
(523 Views)
