Connection for subvi and button
    I am desigining a Vi with a "main selection page" onthe front panel which acts like NI 'Developer Kit Example Launcher' how do i connect? egs. i click on 'ASK' button it will pop up and run ASK modulation front panel diagram. How can i do it? Thanks!
Message 1 of 21
(5,412 Views)
Hi Serina,
try this (easiest) solution:
("Ask?" switch set to latch operation)
Message Edited by GerdW on 04-02-2008 10:10 AM
Message 2 of 21
(5,391 Views)
     Thanks for your reply but can you tell me what is the name for the VI u used with a watch inside the icon? I can't find it in the timing palette.. Smiley Happy
Message 3 of 21
(5,385 Views)
The VIs name is "Wait For Frontpanel Activity". It is lacated on the "Dialog & User Interface" (or similar) palette.
Message 4 of 21
(5,381 Views)
If your version is LV 8.x, it has been moved to the Dialog & User Interface palette.
It is the Wait for Front Panel Activity function.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 21
(5,380 Views)
its "Wait For Front Panel Activity" found in Dialog and User Interface palette
(Oh.. I am quite lateSmiley Wink )
Message Edited by Vsh on 04-02-2008 03:37 AM
Message 6 of 21
(5,379 Views)
3 REPLIES IN 3 MINUTES... WOW ! Smiley Happy
Message 7 of 21
(5,372 Views)
So Sorry but i have to ask you again inside the case structure there is a word ASK inside a square is it also a VI or just label? It should be a Vi isit??
Message 8 of 21
(5,361 Views)
Hi Serina,
that's your "ASK modulation.vi", i just made a somewhat more descriptive icon - seems I failedSmiley Very Happy
Btw. what's the difference between those two versions you attached to your question?
Message Edited by GerdW on 04-02-2008 11:12 AM
Message 9 of 21
(5,359 Views)
Smiley Happy My apology, i attached the wrong file without knowing it after u mention actually i want to upload a program vi and a subvi, subvi is used for the part where i mention when i click on the ASK button it will pop up a window running the ASK modulation VI. These were told by my project supervisor, the program pop up running the Vi should use subvi within the circuit connection to work.
Message 10 of 21
(5,350 Views)
