11-16-2015 11:06 AM
I am having trouble connecting to a scale that uses a rs-232 serial cable. (myweigh i601)
I can communicate with it using hypeterminal, but when I try to communicate using MAX, I get the error message
Error opening resource:
ASRL1::INSTR
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
I have limited experience using serial communication with labview, so any direction to getting this up and running would be great.
11-16-2015 11:08 AM
ASRL1::INSTRVISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
Are you still running Hyperterminal when you try to run your VI? Is anything else trying to use your serial port (MAX, third party application, etc.)? Only 1 program can access the port at a time.
11-16-2015 01:42 PM
Only labview is running
