Connecting to Exfo LTB-8 via LabVIEW
Hi all,
I have LabVIEW 2021 installed.
I'm very new to LabVIEW/computer programming and have little to no knowledge, apologies for the basics in this message.
I've recently completed Core2 LabVIEW training so have some experience with using the software.
I have an Exfo LTB-8 with the following modules inserted into the chassis.
OTDR - 720C
Light Source - 2150
Power Meter - 1750 x 4
Attached is a PDF from Exfo explaining how to connect to this unit via LabVIEW/Ethernet, however, I cannot seem to add this in the block diagram or front panel.
I think the part I'm struggling with is adding this to NI MAX due to not knowing the port name of the device, also page 13/14 on the PDF is confusing, again the lack of knowledge with this.
Any help/guidance would be extremely appreciated.
Thanks in advance,
Bilchu
(1,885 Views)
(1,871 Views)
Try this out.  See if your specific instrument has a LabVIEW driver ready to go.
https://www.ni.com/en-us/search.html?pg=1&ps=10&sn=catnav%3Asup.dwl.idr%2Cn7%3A845&sb=%2Brelevancy&q...
(1,820 Views)
The document talks about a sample LV program. Do you by any chance have it? Can you please forward it?
thanks,
(1,094 Views)
