Connecting an array to cluster to an unbundle into a get waveform components
I have project in school where I have to do speech processing.
However, one of the instructions said that I have to connect
an array to cluster (I set the cluster size to 1) to an unbundle function, which then
I have to connect a get waveform components to the cluster component. When I do
that Labview shows me an error that saids that I have connected two terminals
of different types. how can I fix this error?
(2,518 Views)
The instruction to convert an array to a cluster makes no sense.
There is a function called Get Waveform Components in the waveform palette.
Other than that, we can't help much more unless you post your VI so we can see what you are really trying to do.
(2,515 Views)
