Connecting a Chemyx fusion 4000X Syringe pump to labview
Hey everyone!
Im currently having issues managing my pump from my computer. I tried a modified example, and now I no longer get any errors when I run it. However, the pump still doesn't do anything when I run LabVIEW. When I check the instrument detected, it appears as *IDN? What else do I need to do to make the pump run by LabVIEW? What am I doing wrong? I also validated the port on NI MAX and changed the baud rate to 115200. the pup is also set to have a baud rate of 115200.  Now, when I open the VISA Test Panels Input/Output, I get an error when I click on Query, Read and Read. Bytes.
Can you help me troubleshoot this?
Thanks!
Fusion4000_Manual-12-16-20.pdf (chemyx.com)
(1,071 Views)
What does the Pump respond when running the vi attached ?
(1,007 Views)
What does the pump responds when running the vi attached ?
(1,006 Views)
