Connect a measurement device via Wifi to LabView
within a project that I am doing I need to read and capture the data coming from a measurement equipment that sends them through Wifi, I thank you if anyone has a suggestion like I can do it using LabView, the only information that I have is the IP adress of the equipment.
I have basic knowledge of LabView.
Thank you
(3,214 Views)
Please refer to the suggestions list at the top of the New Message page and provide as much of this information as you can.
When writing your post, please be sure to provide the following:
• All information necessary to troubleshoot the issue (including troubleshooting steps already attempted)
• Error number and/or detailed error message description
• An attachment containing your code in the form of a VI or ZIP
• Applicable VI Snippets and screenshots
• Specific hardware, software, and drivers being used, as well as versions
• You must now use a "label" to indicate whether your post relates to LabVIEW or LabVIEW NXG
  (To do so, select the appropriate option in the "Labels (Product or Category)" section on the right side of the page.)
aputman
(3,191 Views)
Hi omvr18!
A WSN module or a WIFI chassis may fit your application.
Also, there are a lot of examples with these elements in LabVIEW help.
If you are using third party hardware, it would be nice if you tell us more about your instrument.
Kudos are welcome 😉 marked solutions are awesome!
(3,147 Views)
