05-23-2012 01:32 PM
I am trying to connect my PLC (Omron CP1E-NA) to LabView. The PLC supports Hostlink when talking to PC.
I have LabView Full development environment and DSC Module installed. Other modules are avaiable if needed.
My project is to connect this PLC to LabView so that I can develop control interface via LabView. The connection between PLC and PC is RS232 cable.
I am not sure how to configure LabView in order to enable communication with PLC.
Any possible connection methods are welcome. My work is somewhat urgent, so I look forward to your help very much.
Thank you all for your kindly help.
Wei
05-23-2012 03:13 PM
Is it possible to test the connection from PLC to PC using the PLC software? This way you can verify the connection, and then connect with LabVIEW or even better use some manual commands with MAX.
05-23-2012 05:12 PM
PLC's software can communicate with the PLC only via USB. It can connect to a control interface development software via serial cable.
05-23-2012 05:13 PM
As you mentioned MAX, what should I do with manual commands? Thank you.
05-23-2012 05:31 PM
I tried to configure my PLC in MAX. I connected PLC with PC via serial cable. In MAX, it says it works properly. What's the next step? Thanks.
08-08-2012 11:35 AM
hi , i had been trying to establish communication with NI WLS 9163 but not been possible , i used following setting in My plc
port numner - 31415
ip address of module ,
or else let me know what commands i can send to receive response from ni wls 9163 through a third party application ie like my plc
08-09-2012 06:11 PM
Hello Mateen,
I believe that it would be better if you created a new thread for this question. The original thread is attempting communication via rs-232 and your question is related to wireless configuration. Hopefully in a new thread you will have a larger community response relating to this question.
Joel
08-09-2012 06:50 PM
howdo i create a new post/forum thread
08-10-2012 12:18 PM
Hello Mateen,
Here is a forum thread that describes the steps to posting:
I hope you have success finding solutions using the NI Discussion forum.
Joel
04-02-2014 05:46 AM
Dears,
i am also having omron PLC CP1E -NA module, and i would like purchase the labview 2013 development module.
before that i would like to get your opinion for the utilities.
Can I interface with the PlC via Rs232c ,
kindly advice to me.
Regards
R kumarsamy
