Conflict with VeriSTAND Application While Connecting to Target in LabVIEW
While attempt to connect to a PXI target in LabVIEW, I get the following conflict...
My labmate says it is part of the OS and should not be stopped. Is this true? Is there a way around this conflict?
(2,819 Views)
Hello swbpbae,
The Real-Time Startup Application is an executable that has been configured to launch on boot of your real-time controller. It is not a part of the OS and is instead a user-created application. Unless you are relying on the execution of the Real-Time Startup Application, you should be fine to abort the application and continue with the deployment. Feel free to let me know if this gives you any more issues.
Thanks!
Collin D.
Software Product Manager
(2,779 Views)
