Conflict using Labview and a serial port
Hi All,
I am developing a 6 circuit product using Labview and a serial port. 2 of the circuits are identical ( 1 configured as a 14 channel Radio Control servo controller, the other a 14 channel data acquisition board ). 1 of the circuits is a dongle connected to a PC via serial cable/port. The other 3 circuits are RF comms devices allowing dongle and 14 channel circuits to communicate.
The idea is to capture logged data from one 14 chan board and transmit it to the 14 chan servo controller board in "real time". So for example a biped robot can mimic movements of a user wearing a leg harness.
The circuitry and embedded code is virtually finished and I have just started to connect this new hardware to my prebuilt
Labview routine.
I can power up the circuits using Hyperterminal for a couple of hours and keep the connection. This means the PC receives frames of 42 bytes from the logger at 100 hz and is able to transmit frames to the servo controller at 50 hz.
I dont know how Hyperterminal works in order to create this reliable connection but I have tried to recreate the same functionality in Labview but keep losing the link. Resetting the dongle regains the link. I find I can run both the logger and servo controller separately but as soon as I connect both at the same time I lose the connection within seconds.
I undestand the dongle is set to receive logger frames until a write request occurs at which point receive is put on hold untill the write is finished. The RF side of things is configured back and forth as Tx and Rx. Clearly it can cope with rapidly switching this way when Hyperterminal is used.
Simply, how do I achieve the same function as Hyperterminal ( I'm guessing ).
I
have struggled before to get Labview doing Rx and Tx at the same time and I suspect this is a similar type of issue.
Hopefully some can help
Best Regards
Chris - Robotic Systems.
(2,753 Views)
Without seeing your vi design, it sounds like you may be trying to read/write the same serial port at the same time. Is your vi structured into a state machine or event based approach??? I have used labview to do bidirectional communications with a Yokogawa DL708 oscilloscope using Visa and the serial port. Are there any Visa drivers available for some of your hardware??
(2,753 Views)
