Conflict Message when deploying Softmotion axis ?
Hi ,
I get the follow everytime i attempt to deploy my softmotion axis
" Access Denied. The NI Scan Engine is already in use by another process. The other process might be a LabVIEW project or a built application. Please
close that project or application and try again. If you are attempting to run a built application from a project that has already started the scan engine, you
need to close and reopen the project and run the application before deploying another project item."
Can someone help me please ?
(3,125 Views)
You can only use the scan engine with one project at a time. It sounds like you have multiple projects that are open and are using the scan engine. Try closing LabVIEW completely (you might even verify that all instances of it are closed in the Windows Task Manager) and then only opening your attached project.
(3,100 Views)
