Confirmation of laser beam in an optical tweezer
Hi Guys,
I am working with an optical tweezers whereby I was unable to confirm the presence of the laser beam in my software. I was wondering could it be due to the FPGA driver which i am using? Or am i on the wrong track to presume that the laser works under the FGPA platform? If so, which area should i look into in order to solve this problem?
As attached is a glimpse of my software.
However, when i used another software, it clearly shows the presence of the laser beam.
Please kindly advice. Thank you in advance.
Best Regards,
Scott
Message 1 of 1
(2,461 Views)
