Configuring NA display for multiple plots with Labview.
I'm new to labview. I'm trying to figure out how to get labview and an Agilent network analyzer (E8803A) to work together. I've gotten some of the basics to work. I can set the frequency range, number of samples, etc. that I want the NA to test over. I need to figure out how to get Labview to set the NA display so that it shows 2 windows stacked on top of each other. I would like two plots, one of Magnitude and one of Phase. Right now I can only generate one display window on the NA with my VI. I downloaded the Agilent NA drivers from the NI website. I'm sure the functionality is in one of those files somewhere, but I don't know which one.
Any help would be appreciated,
Thanks.
(2,797 Views)
Please check in the programming manual of NA to see if their is a command that can show you two screens instead of one. Some time this may not be in the driver.
Or open up the tree of the NA driver youdown loaded and look at each VI to see if their is a selection for the setting two screens.
Naresh
(2,797 Views)
