Configuring ClearCase with LabVIEW SCC
I am developing VIs with LabVIEW pro. We are using ClearCase for SCC and I would like to configure LabVIEW with ClearCase.
VIs are stored under vobs on a world wide network.
Does anyone know how I can do?
Second question, is it possible to configure ClearCase to use the LabVIEW pro compare tool? This will give ClearCase the capability to compare VI versions.
BR,
Pascal.
(3,038 Views)
ClearCase is not supported by LabVIEW, if you want to use a SCC, you can perform this task with the following SCC providers: Perforce and Visual Source Safe and Built-in.
Built-in SCC is recommended only for small projects and is available in LabVIEW at no additional cost. “Microsoft Visual Source Safe” and “Perforce SCM” are complete SCC tools that are fully integrated into LabVIEW but must be purchased from the corresponding vendor.
You can find more information at the following link:
http://zone.ni.com/devzone/conceptd.nsf/webmain/69ea27204d24f78586256e2400773abe
If you really want interfacing LabVIEW and ClearCase, VI Engineering can perhaps help you:
http://zone.ni.com/devzone/conceptd.nsf/webmain/ddaa22e726919f118625700000009ca9
Best regards
Alexandre D
AE, National Instruments
(3,021 Views)
