Configuration wizard of a Vi express
Is it possible to open the front panel with some button of a subvi during the execution of a Configuration Wizard of a Vi express ? I tried, but the execution stops when the subvi is executed without shows its front panel.
I tried also with different Execution property, but the results was the same.
(2,836 Views)
To make a subVI display it's front panel when called, you can do it several ways. One way is to right click the subVI in your main, select SubVI Node Setup and then select Show Front Panel When Called and Close Afterwards if Originally Closed. Another way is to change the VI Properties of the subVI. The VI Property you want is on the Windows Appearance category. Select customize and you'll see the same options about front panel display.
(2,836 Views)
Could you please tell me if the answer given below solved your problem? Bye.
(2,836 Views)
