Configuration problem with LabVIEW and Measurement & Automation
I have been trying to run the NI-DAQmx for the last couple of days but it is not working properly or actually not working at all. I am trying to acquire data using a PCI-6143 card. Everytime I am trying to open the Measurement & Automation explorer it tells me to check the configuration. It says: "Executable version (7.1.1) doesn't match resource file (7.1). Check your configuration." When I then click ok nothing happens I have to close it using the task manager. I tried to check the configuration but even that does not help or does not even work. How will I be able to get it run again. I talked to some of my colleagues and they told me that it has never been a problem before. Is there any other way then reinstalling it?
Thank you for your help
(3,227 Views)
Try to repair the LV 7.1 runtime engine.
(3,222 Views)
Where do I do that or does that only work with the CD?
Thx
(3,209 Views)
I'm using a french version of WXP and therefore the names may be incorrect :
Control Panel >> Add/Remove Programs >> National Instruments Software >> Modify/Remove >> NI LabVIEW Run-Time Engine 7.1 >> Repair
(3,198 Views)
Thanks a lot. I did as you described and it is working again.
Thanks!!!
(3,175 Views)
