Configuration file integer type
  I have integer data type in my ini file.  I have selected integer data type in my program while reading that value.
If that value is empty in the ini file then my function returns error.  I gave default value as 0.
My function returns error and then don't read any other values after that.
How do I solve this problem without changing that empty field to 0?
thanks
trupti
(2,852 Views)
you must be wiring Error out of the vi generating err. to the Error in of the next VI.
In such a case all the vis that follow the vi generating err. will not execute. to avoid this error you should reset the err before executing next vi.
I hope the problem is same as the one i described.
if you can put your code here, that can be very much useful.
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(2,835 Views)
