Configuration file in LabVIEW real time
"Hai
Am developing a real time s/w which reads the data from the file, the information in the file are mailnly configuration data, like which channel should be read and which channel should be controlled. I needed to know if Configuration file VI's provided in LabVIEW can be used for this situation. Also the Configuration file should be created in labWindows / CVI and downloaded on to the s/m running on RTOS. can this be achived?
Thanks for the reply
Arun"
(2,929 Views)
We use LabVIEW configuration file VI's all the time with LB Real-Time. It should do exactly what you want.
I'm not a CVI User, but you can use the inifile.fp driver file to read/write config files in CVI.
So yes, both systems support reading/writing INI-type config files.
(2,929 Views)
Hello Arun,
Thanks for contacting National Instruments. I have already answered your duplicate post at: http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HFORCEKWTID=118896:5&HOID=506500000008000000F4F60000&HExpertOnly=&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0 .
For future reference, please post to only one of the boards and try not to submit duplicate posts. An Applications Engineer will look at and try to answer your post, regardless of its location or duplicates.
Thanks!
A Saha
Anu Saha
Academic Product Marketing Engineer
(2,929 Views)
