Configuration NI 9862
Search and connect your cRIO in NI-MAX.
There you can change the port-number of the CAN-device inside your cRIO.
It also might be necessary to update or change the firmware of the CAN-module ( dialog are available from NI MAX).
NI MAX also offers a dialog to "blink" the LEDs on the CAN module.
Regards, Jens
Kudos are welcome...
Message 11 of 12
(698 Views)
I am facing the same issue however i am able to blink the LEDs using max. But running the LabVIEW example gives the same error as mention the this thread.
Message 12 of 12
(562 Views)
