Conditional probes
Hello everyone,
I have a question regarding conditional probes. What conditions allow you to have a conditional probe. I have seen in some of my subvis that the condtional probes are not always available. See attached picture. I can have conditional probe on the output of one add function, but not the other. Why is this?
thanks
(3,309 Views)
Under "Custom Probe" you can normally see the list of the last Customized Probes you used. LabVIEW has a list of already defined Conditional Probes which are already programmed.
You should go to "Custom Probe -> New... -> Create from existing Probe and choose the Probe (f.e. Conditional Double Probe.vi) you want to use. After choosing, the probe will appear directly by "Custom Probe".
Regards
Ken
(3,294 Views)
