Condition labview
I have to create a condition here ,I have to create a loop that waits for M , I have to look for the character "M" which is my first string character and as soon as I find M I take the characters until we see "E" the end character .
as soon as I see "M" I stop and do the treatment.
help.
Message 1 of 12
(4,223 Views)
Hi Debutante,
Right now your VI looks for "T1:" and "T2:" to recognize a "full message".
All you have to do is to replace this by code looking for "M" and "E"…
What have you tried? Where are you stuck?
Btw. in general it helps to cleanup the block diagram to better understand the code:
Why do you read the serial port byte by byte? You configured a TermChar, so you should read full messages by requesting substantially more bytes (like 999)!
Message 2 of 12
(4,215 Views)
I have to look for the character "M" which is my first string character and as soon as I find M I take the characters until we see "E" the end character.
I would set it up something like this.  The idea is to read 1 byte at a time until you read the M.  Once you read the M, read the rest of the message (termination character set to be E) and then parse that message.
Message 3 of 12
(4,170 Views)
that’s what I’ve been trying to do, my teacher told me I had to do a loop that waits for "M" and then does the treatment and stops when we have "E", he told me to do a condition at the top left of my LabVIEW , that I will have to make a 3rd line of regex parallel to the other two.
We do our best to be sure to get the full string because labview can launch in the middle of the buffer so not necessarily start with the beginning of the string.
Message 4 of 12
(4,162 Views)
Like that? What passes for the false part?
Message 5 of 12
(4,155 Views)
i dont send the screen -_-
Message 6 of 12
(4,154 Views)
The FALSE case just passes the VISA Resource and error cluster through.  But it is in the TRUE case that you parse the message, however that should be done.
Message 7 of 12
(4,130 Views)
Message 8 of 12
(4,115 Views)
Message 9 of 12
(4,100 Views)
that dont work , so nobody can help me?
Message 10 of 12
(4,099 Views)
