Condition input to "db tools update data.vi"
I am trying to modify a database record based on the ID number. I looked at the Database Update.vi example but it has the Condition input of "db tools update data.vi" wired to a constant "where %s='%s' and %s='%s'  ". I cannot find anything that shows how to change one record based on the ID number.
Message 1 of 10
(4,436 Views)
Simply wire a string constant to the condition input which is "WHERE ID = <DESIRED ID>". This is essentially the WHERE clause for your SQL statement. Make sure that 'ID' equals the column name of the column you are using and that "<DESIRED ID>" equals the actual user ID.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(4,421 Views)
Since the <DESIRED ID> is not a constant, just concatenate strings to get the correct formatting?
Message 3 of 10
(4,410 Views)
This code snippit did not work.
Message 4 of 10
(4,399 Views)
What DB are you using?
Mark Yedinak
LabVIEW Champion
Message 5 of 10
(4,397 Views)
Microsoft JET Database Engine.
Message 6 of 10
(4,394 Views)
Are you getting any errors? Is the ID field a string? Your syntax in the WHERE clause indicates it is a string column. Is ID a numeric column? If so, drop the quotes around the ID.
Mark Yedinak
LabVIEW Champion
Message 7 of 10
(4,389 Views)
I dropped the quotes and no longer get any errors, but it changes all of the rows, only 5 fortunately, in the DB.
Message 8 of 10
(4,375 Views)
Did the 5 rows all have the same ID? IF so, it did what you asked. If not, then something would appear to be wrong with the WHERE clause. To be honest, I rarely use most of the VIs in the DB toolkit. I generally only use Open, Close, Execute, and Fetch. My applications include the actual SQL in the code. As a rule of thumb, I generally only use stored procedures in the DB. This provides a nice API to the DB and allows changes to the schema without requiring changes to the application provided I maintain the calling structure of the stored procedures.
Mark Yedinak
LabVIEW Champion
Message 9 of 10
(4,372 Views)
I gave up on "db tools update data.vi" and modified the "Database Fetching.vi" to read my data. It looks a lot easier to change and write the data. Time will tell.
Message 10 of 10
(4,330 Views)
