Concurrent multiple external executables and DAQ in LabVIEW
Dear LabVIEW Users,
I am using LabVIEW 2009 with USB 6008 for DAQ from accelerometers. Besides, DAQ from the accelerometers, I have couple of other external executables which triggers the two different process (data write). By using System Exec.vi, I can trigger these external executables. But the external executables data writing starts at different time, as an example, say exe1 takes 1 second long to start writing data to a text file, where as exe2 takes 20 seconds long to initialize and to start writing data.
Therefore, is there any way even I trigger multiple external exe files, and I can start data write from all of them at the same instance along with DAQ from accelerometers.
Thank you and much appreciated for your help
With Regards,
Paghalaya
(2,694 Views)
You could try to speed up the execution of the 2nd VI through code optimization, but is there any way you can combine the VI's? Starting a simultaneous task would be much easier. Is there any reason for using multiple VI's?
(2,668 Views)
Hi Eric,
Thanks for the reply. Infact, I am using LabVIEW to trigger multiple external executables of depth camera, RGB camera and GPS system which are from different vendors and API too. At the same time, LabVIEW, DAQ-mx will assist me to read and write the data LVDT, accelerometers or other voltage output devices (somtimes even I may send digital/analog input to LVDT). So this was the first option came to my mind when I just started learing the LabVIEW.
Secondly, when I did some homework on this kind of problems. I was enlightned by Google searches that concurrent program, threads,  processes and other OS related programming tools can be implemented to overcome this problem. But I am not sure whether this can be easily and successfully implemented (since my background is civil engineering, but I am familiar with C/C++) in a month or so. I also came to know that NI-DAQ C examples are already provided by NI.
In a nut shell, I am planning to take the leverage of NI examples.  In other words, planning to make up a master program which incudes all the headers, main program and collectively seperate programs for RGB, depth and other hardwares. Therefore, is it possible to build a program something similar to my plan using OS promming tools efficiently? Are there any cool resources for that?
Thank you,
With Regards,
Paghalaya
(2,660 Views)
