Concurrent ADC/DAC timing
I'm doing an echolocation experiment with the USB-6341 -X Series DAQ.  I can output a wav file through an analog output and collect the input through one of the analog inputs.  My problem is that I can't figure out how to time the two functions in relation to each other.
I'm pretty new to Labview so one solution I was thinking was to start logging the data after I've finished outputting the wav file.  I don't know how to do that in Labview because it seems like everything runs in parallel.  How do I get things to run in a specific order?  I was looking at the time delay or wait functions but they don't have any sort of input or output to connect to anything so I don't know how to put them into the program.
Or it would be better if I could trigger the data logging within labview so that it starts during the first rising edge of the signal.
Any help or alternative ideas would be appreciated.
(2,729 Views)
There are a lot of example VIs in the NI Example Finder (Help » Find Examples) to help you get started with synchronization (and pretty much everything else).  You can find the DAQ synchronization examples under Hardware Input and Output » DAQmx » Synchronization.  You should be able to start with one of these examples and modify it to fit your application.
Jayme W.
(2,686 Views)
