Concatenating multiple numeric data into string
1. I have to contain multiple numeric data into string. 2. Attached is VI. 3. problem is on front panel it seems very clean since I have created tabs. But on block diagram it seems very cluttered. How can I reduce it?
(4,255 Views)
No VI attached.  You may need to put it into a zip file first.
But multiple numerics can be easily formatted into a string.  You could use the Array To Spreadsheet String or you could use the Format Into String.  Tab and comma are the two common delimiters used here.
(4,239 Views)
Sry abt that. Attached is VI & in zip folder also.
(4,230 Views)
The Format Into String does it all for you.  This example only has the first 4, but you can have as many inputs as you need.  I highly recommend reading the help article on this function.
(4,216 Views)
I had done the same as you can see in block diagram.
I think I didn't phrase Q right.
Actually I have two many numerics so it takes large space in block diagram. Like in front panle I have categorized them into tabs so they seems better organized.
In block diagram it seems a big mess. Also placing while loop on large space is again a cumbersome process.
(4,208 Views)
Now that I have thought about this a little more, I think what you really want to do is make a cluster with your 4 items and then put that cluster into an array.  This would eliminate the need for the tab control and allows you to process all of the elements using a FOR loop.  Cleans up both the front panel and the block diagram.
(4,192 Views)
