Concatenate string to dbl array
Hello!
I am having trouble inserting a concatenate string into a array with random numbers. The goal is to display the concatenate string into a single element with 8B,8T,4,6 or a possible 4,6 if a switch is turned off. I have used scan from string, and am having no luck. Any thoughts on what to do?
Thank you!
(1,872 Views)
You are mixing strings with numbers, so everything should be converted into strings.
(1,855 Views)
