Concatenate VIs
i work on a project that consists at automation of the VI unit test.
First, the user should choose from a combo box the VIs that should be tested, then those VIs will be displayed in the front panel and the user will connect them.
My problem is : i have no idea how can i program that!!
How can i call other VIs and display them in the front panel as blocks with inputs and outputs!!
Thx for your response.
(2,555 Views)
I am not sure how you can achieve in showing the vi as a block containing input and output but you can certainly execute the vi's depending on the selection of the user by calling the vi's dynamically and executing them.
(2,548 Views)
You can user VI Server to load a VI into a sub-panel, set the input values and then run the vi.
Rather than trying to write your own unit test framework, you might want to look at VI Tester.
http://forums.jki.net/topic/985-vi-tester-home-page/
(2,545 Views)
