Concatenate Images
I needed this.  Maybe others can make use of it.
(1,630 Views)
Hey Paul I love this.  Are you aware of the string manipulation needed for translating the 2D Picture control?  Norm Kirchner posted over on LAVA years ago about how you can quickly translate an image by modifying the opcode parameters.  Not sure if it would help performance here but I suspect it would since your method has several image conversions that might not be necessary, especially if one (or more) of the inputs is a 2D picture.
https://lavag.org/topic/17138-2d-picture-translation-movement/?do=findComment&comment=137613
(1,501 Views)
Unfortunately your .zip file is no longer available.
(1,462 Views)
I was able to download it.  Are you logged into your LAVA account?  Also code is included in the other post I made recently about making a meter using a picture control.
(1,455 Views)
Here is your image translator restyled according to the way I like things styled.
(1,417 Views)
