Comunication Epos2P and Labview
I'm making a proyect with Epos2P and Labview by USB and i got to connect it with the PC opening:
VCS Open Device Dlg
Select:
-Epos2
-MAXON SERIAL V2
-USB
-USB0
-1000000
-500
getting a "KeyHandle out"
VCS Set Protocol Stack Settings
I write here the "KeyHandle out" i got before
VCS Open Device
I write the same I wrote in the first part and i got other "KeyHandle out"
I do all things just selecting "Run" and not "Run Continuosly"
After I open for example "VCS EXAMPLE_move with velocity" or other (using the same "KeyHandle out") and appear this error -->  Illegal Command (0x0F00FFBF)
And when I try to use "VCS Get Encoder Parameter" appear:
VCS Get Encoder Parameter.vi<ERR>
Maxon Serial V2 Protocol - Bad Data Size received (0x34000004)
I have Labview 2011
Epos2 P 24/5 conected by USB
Motor Maxon DC RE 30 ∅30 mm, Graphite Brushes, 60 Watt
Encoder MR, Type L, 256 - 1024 CPT, 3 Channels, with Line Driver
(2,985 Views)
I have never use an EPOS2 P driver but the first thing I would do is to check if the driver and LV library are the same than those for EPOS2.
(2,938 Views)
Thanks JB, my problem was with the library....it was not the correct. It's already working.
(2,920 Views)
OK, I'm glad to hear !
(2,916 Views)
