Computer speed problem in Measurement and Automation Explorer
I am using Labview7.0 & in that for graph i m using Measurement and Automation Explorer. My scada is running since last 3 months continously.We have found that initially computer speed is good to see data in Measurement and Automation Explorer for trends but after 15 days computer becomes slow. Now if i am trying to see last 24hrs data then computer is getting very much slow.
Pl suggest how to improve speed of computer to view data fast in Measurement and Automation Explorer
& how to retrive data from database Citadel 5 Universe?
vijtin....
(3,380 Views)
Hi vijtin,
IMHO MAX isn't made neither for long term data observation nor for visualisation of big datafiles...
(3,373 Views)
I agree. MAX is intended to be used to configure your hardware, check what you've got installed, create DAQ tasks, run some test measurements, that sort of this. It's not designed to replace your own program, which is what you should be writing in your particular case.
(3,363 Views)
